My card the evga 770 sc acx will not boost to its boost clock the full time I play a game. I start a game up for an example bf3 and the gpu boosts to its 1163mhz for about 45 seconds then it returns to its base clock which is 1111mhz and stays there. Can someone plz tell me why it wont stay at the boost clock like it is supposed to do.  My temps are very good around 45-50 celcius
https://linustechtips.com/topic/59562-problem-with-gtx-770/
Do you have Vsync on? If not what are your frames?
No i dont use vsync. When I first start playing my frames are at its highest it will ever be which is 1163mhz.....Like i said.....then the frames drop about 25fps average and then as soon as i see that i alt tab look at precision x and see that.. hey the gpu just clocked down to its original speed and not boosting anymore....does this make sense
https://linustechtips.com/topic/59562-problem-with-gtx-770/#findComment-808085
No i dont use vsync. When I first start playing my frames are at its highest it will ever be which is 1163mhz.....Like i said.....then the frames drop about 25fps average and then as soon as i see that i alt tab look at precision x and see that.. hey the gpu just clocked down to its original speed and not boosting anymore....does this make sense?
What you have to do is piss on it and then put a puck on top.
ASUS VG248QE 144hz | CM Storm Scout 2 Advanced | MSI Z77 GD65 | i7 3770k @ 4.2GHz | GTX 780 3GB FTW ACX |
Corsair RM750 | H100i | 8GB Corsair Vengeance | Corsair Neutron 64GB SSD | WD Black 500GB 7200RPM | ROCCAT Kone XTD | Microsoft Sidewinder
https://linustechtips.com/topic/59562-problem-with-gtx-770/#findComment-808150
25 FPS? I don't think that's only an issue with your card, a 50mhz clock drop won't drop you 25 frames. You have some other issue in your system. Are you using a fresh install of windows, is this a new card, a new system, what is your most recent hardware or software change, are your drivers the most recent? (If so do a rollback.)
Error: 410
https://linustechtips.com/topic/59562-problem-with-gtx-770/#findComment-808197
Its most likely heat issues.
The 7xx series Nvidia cards perform specifically based on how hot they are.
Perhaps it gets too hot and then downclocks.
Try manually ramping your fans up to 100% and then play, see if anything changes.
My Rig: AMD FX-8350 @ 4.5 Ghz, Corsair H100i, Gigabyte gtx 770 4gb, 8 gb Patriot Viper 2133 mhz, Corsair C70 (Black), EVGA Supernova 750g Modular PSU, Gigabyte GA-990FXA-UD3 motherboard, Asus next gen wifi card.
https://linustechtips.com/topic/59562-problem-with-gtx-770/#findComment-808246
