G402 issues
Go to solution Solved by Naeaes,
Hmm. Maybe unistall and re-install the gaming software + drivers?
Hello guys. I'm really confused at the moment, my G402 left and right click are not working on my desktop, but when I plug it into my laptop it works fine without any issues. I've tried restarting my desktop, plugging it into different USB ports, still doesn't work. :( Please help me.
https://linustechtips.com/topic/594825-g402-issues/
2 minutes ago, Naeaes said:
Do you have a second mouse to cross-check on your computer?
Yes. It works with no problem. :(
https://linustechtips.com/topic/594825-g402-issues/#findComment-7732520
Working now! Logitech gaming software was messing it up! :D Thanks for your help
https://linustechtips.com/topic/594825-g402-issues/#findComment-7732539
