Need help finding a small speaker amp
https://linustechtips.com/topic/594685-need-help-finding-a-small-speaker-amp/
Bluetooth is an expensive add-on that isn't really worth it in my opinion if all you want is to play music from your phone into your speakers.
Something like the SMSL SA-60 has a 3.5mm input in the front and RCA input in the back so you can hook both your PC and your phone up to it and switch between them as well.  Half the price of the BT options too.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
that would work perfectly, thanks
