Sometimes, while listening to spotify, it gives me the "song is not availible" error for no apparent reason. Then if I try to play any other audio (youtube, itunes, etc) it refuses to start. Youtube videos will play silently, and itunes songs will play but not progress foreward as of they were paused. VLC media player will play, but silently.Any ideas?
Just a guy who peaked at building back in the days of the GTX 980. If you see me here, assume i have technical knowledge akin to a committed hobbyist builder back then. If something's changed, you'll need to tell me(nicely plz). I'm probably asking for help with the modern build scene since I have no clue what's going on.
https://linustechtips.com/topic/594539-sound-cuts-out-randomly/
Do you use a USB headset / speakers?
Do you hear a pop before it stops working?
Are you able to disable the device, enable it and it works? (Control panel -> Sound -> Playback devices -> "default one" -> Right click -> Disable -> Right click -> Enable)
It's not a race to the bottom.
https://linustechtips.com/topic/594539-sound-cuts-out-randomly/#findComment-7730883
