(So I think I posted this in the wrong spot before, in the Motherboard section, oops)
Still trying to narrow down my issues to the cause. As far as I can remember, since I built my new PC, I've had this issue.
I just got a new motherboard (replacement from Asus), and none of my hardware is overclocked, no XMP, no GPU overclock, etc...
(I got this problem even months ago, when I DID have overclocks set, and additional voltage added to System Agent, VCore, and DRAM.)
Sometimes, while turning my PC on, I'll get the QCode "bF." The machine turns on, no video signal or UEFI BIOS, fans spin at 100%, and after maybe 90 seconds, the PC turns off, and stays off. If I turn it on again, the same things happens.
Motherboard manual says that QCode bF is "reserved for future AMI codes" :| Real helpful ASUS...
The only thing that can break this loop and successfully boot is either:
1.) Reseating my RAM.
--or--
2.) Shutting down while the PC is on (and in aforementioned black screen, fans spinning, etc...) If I shutdown while this is happening and turn the PC back on again I get the American Megatrends screen with the "Overclocking Failed" message. This leads me into the UEFI, where I can then shut down, and the PC might boot again.
Anyone have any idea what's going on here? I'm testing memory with memtest, 1 stick at a time but so far no errors on three sticks. I doubt the motherboard (a replacement I JUST got) is bad, so I'm ruling that out. I really don't want to believe it's the CPU (though I do have a replacement plan on it, so that wouldn't be a huge deal). I've read threads about people also getting bF QCode with the same PC behavior, and the usual response is that there is an unstable overclock, or something needs more voltage (VCore, System Agent, lots of answers...) but as I mentioned, I have NO overclock yet. Which doesn't make sense.
CPU  5820k - 4.0GHz @ 1.27V  |  MOBO X99-Pro  |  RAM 16GB Ballistic @ 2133MHz  |  PSU HX750i
 COOLING  Kraken X61 - 6x NF-A14 iPPC  |  DRIVES  256GB 950 Pro - 2x 1TB Travelstar - 1x 1TB WD Black
GPU  EVGA GTX980 SC |  CASE  R5  |  OS  Win 8.1 Pro  |  MISC   Cablemod C-Series White Set
https://linustechtips.com/topic/594262-x99-pro-qcode-bf-pc-will-not-boot-help/
