My friend is having issues with his pc, in that it crashes seemingly randomly (usually when under some sort of load), and fails to post after playing a game.
His specs:
i5 4690
msi B85M - g43 motherboard
corsair cx600 psu
2x 2 4gig memory sticks (1866mhz)
evga gtx 970
He has concluded that whatever the memory configuration, the computer doesnt post after playing a game. He has had many problems with this pc before and has RMA'd every component with scan, other than the gtx 970. None of the parts have ever been overclocked. We are struggling to troubleshoot the problem and make the computer stable. Anyone got any ideas? Im feeling that its a problem with the motherboard, but not sure.
https://linustechtips.com/topic/593624-crashing-issue/
Was the OS upgraded or clean installed?
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/593624-crashing-issue/#findComment-7719505
2 minutes ago, toggleguy said:
Upgrade
Firstly, if you can get some error codes or memory dumps from Event Viewer, it could help to find the cause.
I've experienced a lot of problems with upgrades.  It always seems like the drivers don't translate correctly or something of that nature, that's why I asked.  If you can, try a clean install with fresh drivers.
I usually go after hardware as a last resort, but I've heard bad things about that particular PSU.  If it comes that point, I would test the system with a different PSU if you can.
https://linustechtips.com/topic/593624-crashing-issue/#findComment-7719559
Hey, I'm the friend he's on about,So I fresh installed win 7, during a driver installation it required a restart, it then restarted and didn't post. I forcefully shut it down and it then posted but completely ignoring the 970 and sending the monitor output through the mobo
I don't know what to do, thanks
Unplugging the 12 pin connector to the 970 and putting it back in causes output through the 970
https://linustechtips.com/topic/593624-crashing-issue/#findComment-7720146
