If you would like some helpful advice I suggest you include your budget and intended use.
CPU - Ryzen Threadripper 2950X | Motherboard - X399 GAMING PRO CARBON AC | RAM - G.Skill Trident Z RGB 4x8GB DDR4-3200 14-13-13-21 | GPU - Aorus GTX 1080 Ti Waterforce WB Xtreme Edition | Case - Inwin 909 (Silver) | Storage - Samsung 950 Pro 500GB, Samsung 970 Evo 500GB, Samsung 840 Evo 500GB, HGST DeskStar 6TB, WD Black 2TB | PSU - Corsair AX1600i | Display - DELL ULTRASHARP U3415W |
2 minutes ago, Prince Dawson said:
Hi guys
Im building a new gaming PC and i need help for a CPU, how many cores would do?
thanks
4 Is what most games will run with but games in the future may begin to use more cores. Also if you are doing things such as 3d rendering or video editing/recording you'll want a 6 core
- SSUPD Meshlicous - Z170I - i7-6700K - Gigabyte 2080 - 16GB Corsair Vengance - 850 EVO 1TB - H115i ICUE Link- SF600
1 minute ago, Prince Dawson said:
I've got a 600 dollar budget since i already have a 4TB HDD
i5 6400/6500 should be doable for your budget.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($26.99 @ Newegg)
Video Card: XFX Radeon R9 380X 4GB DD XXX OC Video Card  ($218.98 @ Newegg)
Case: Thermaltake Versa H25 ATX Mid Tower Case  ($23.30 @ Newegg)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $559.24
Generated by PCPartPicker 2016-05-08 05:04 EDT-0400
16 minutes ago, NunoLava1998 said:
Oh, gaming? Get an i3 (100$ price range) or a i5 (200$ price range).
You kidding me? I'm sorry but you're very wrong. i3 is not intended for gaming at all and it would perform very bad. NEVER consider an i3 for heavy workloads.
It's better than the Pentium, and it is virtually quad-core, so much better.
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
how many cores does an i3 have @Pardeep01
Maximum 2 cores. And cores are not the only thing that matter in a CPU you know. You should look at the frequency, it's features like turbo boost or hyperthreading, if it's overclockable or not.
Yeah well the reason most game developers recommend us quad-core i5s and i7s is because they're virtually 8-core. And that's the most rhetorical answer I've ever heard. "Better than a Pentium".
it is a dual core processor with 4 threads. not the best for gaming, but it'll do just fine in a budget gaming pc.
