Yesterday I went to turn my pc on and it would not turn on, I proceeded to take my AX1200i out of my pc and I have self tested it and paper clip tested it and it passed both. I've also tested it on a different motherboard and again booting wouldn't happen. I've tested all the voltages on all the 8 pin connectors and on the 24 pin connector and there all reading what they should be reading so I don't know what is wrong with it. I can't RMA it either as I brought it off eBay 1 year and 9 months ago and don't have proof of purchase.
So please help me..
My Specs are:
Main PC:
CPU: i7 4770k
GPU:R9 280X
Motherboard:GA-Z97X-SOC Force
RAM: 4x 4GB Corsair vengence DDR3
Other Pc:
CPU: I7 920
GPU: NVIDIA GTX 280
Motherboard: Foxconn Bloodrage
RAM: 3x 4GB Corsair vengence DDR3
https://linustechtips.com/topic/591760-help-ax1200i/
So please help me..
My Specs are:
Main PC:
CPU: i7 4770k
GPU:R9 280X
Other Pc:
CPU: I7 920
GPU: NVIDIA GTX 280
There's really no trick to get it working bud.  Sounds like you did a great job of trouble shooting on your own.  If you did the tests and then tried a separate known working board and the PSU still didn't work, you've got a bad PSU.
https://linustechtips.com/topic/591760-help-ax1200i/#findComment-7700224
Oh well it had been working for over a year just came to it yesterday and it hadn't worked im well confused.
https://linustechtips.com/topic/591760-help-ax1200i/#findComment-7700237
