Which fans should I be using?
Which fans should I be using for my build? The SP series or the AF series? I personally think the AF series for case fans and the SP series for the heatsink on my Hyper 212 Evo! Am I right?
Corsair AF Series: Case Fans
Corsair SP Series: Heatsink Fans
https://linustechtips.com/topic/59174-which-fans-should-i-be-using/
Yes you are correct.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
people will not agree with this
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
So i am assuming you are talking about corsair fans, but there are other manufacturers that makes great fans as well. For example, noctua makes exelent quiet fans.
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
Yeah, I'm talking about Corsair fans! I'm doing this because I have a color theme going on (With the rings)
If you are using the fan mounts where there are air filters, I would get the SP series to get better airflow.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
Between those two, you are correct.
AF = Air Flow = High CFM = Good at moving unimpeded, free-flowing air = Good case fan
SP = Static Pressure = High Static Pressure (Shockingly enough) = Good at forcing air through a tight space = Good heatsink fan
The general consensus in here, though, for heatsink fans is: you can't see them, and want bonus points from Linus, use Noctuas. If you can see them, and care about appearance, then use Gentle Typhoons.
I can give the GT1850's a personal recommendation, too :)
But if you're set on your colour scheme, then you are, indeed, on the right path.
Intel 3770K @ 4.4GHz (Summer) - 4.6GHz (Winter) / Asus P8Z77-V Deluxe / EVGA GTX 680 /w Arctic Twin Turbo II / 16GB Corsair Vengeance @ 1866MHz / Samsung 840 Pro 128GB (Steam) / OCZ Vertex 4 128GB (Boot/Office/Steam) / Seagate Barracuda 2TB x2 (RAID 1, Storage) / Asus Xonar D2X / OCZ 1250W ZX / H80i /w 2 x Gentle Typhoons / Cooler Master HAF X /w Pioneer Blu Ray, Aerocool V12XT, 4 x Cooler Master MegaFlows (Red) / Logitech Z906, G930, G19 & G700
