Sorry to repost but nobody answer and I really need some help.
Ok, so I build my computer in January and it has been running like a dream. However yesterday I was watching a youtube video and it the sound was strange like scattering.
I restarted my computer and the first MSI screen scatter (like a very slow loading page) and it takes much longer to turn on my computer. As soon as I am on the windows starting screen it works normal again. What could cause that? is it fixable?
I am going to take a video of it so you guys can see what I am talking about
I am uploading the video. It took 1:20 to boot :(
Thanks in advance
PC config:
I7 6700k OC 4.4ghz
MSI Z170A M7
Samsung Evo ssd
2x8gb Corsair vengeance
Titan X hybrid
Corsair AX 860
https://linustechtips.com/topic/591725-need-some-help/
Thanks in advance
PC config:
I7 6700k OC 4.4ghz
MSI Z170A M7
Samsung Evo ssd
Titan X hybrid
Corsair AX 860
Quote this comment and type or paste the video link when you have it.
https://linustechtips.com/topic/591725-need-some-help/#findComment-7699954
Sorry for the quality I was just trying to show what the computer does.
What is weird is that as soon as I am on windows it works great.
Did this just happen out of the blue? Did the actual PC performance change also or is it just the boot up that is slow?
https://linustechtips.com/topic/591725-need-some-help/#findComment-7700022
Yeah it happened 2 days ago. I was watching youtube the sound of the video was messed up. Restarted my computer and it took forever to boot.
Performance have not changed. And I scanned for malware and viruses.
It just boot very slow... Used to be like 15-20s top.
https://linustechtips.com/topic/591725-need-some-help/#findComment-7700038
It must be the SSD. Open up the PC and check that the SATA cable is connected properly.
https://linustechtips.com/topic/591725-need-some-help/#findComment-7700055
7 minutes ago, jetstarkiller said:
Well I unplugged the SSD plug it back in. Still the same.
I tried with another sata cable still the same.
I think that the issue is with the SSD then. I cannot confirm it 100%. I would recommend taking the PC to a repair shop and then they can do a better diagnostics.
Sorry that I cannot be of more help.
https://linustechtips.com/topic/591725-need-some-help/#findComment-7700128
Should I try to boot it from another drive. I have some hard drives that would not be fast but it should not take 1:20 even with a hard drive?
Also if it was the SSD should my computer be slow all the time? and not just during the boot.
https://linustechtips.com/topic/591725-need-some-help/#findComment-7700177
~Yes! Try that. If the other hard drives also have issues, then it is a motherboard issue. But if the hard drive is a HDD, please note that it does not take 10 seconds to boot up like a SSD.
https://linustechtips.com/topic/591725-need-some-help/#findComment-7700191
