Will i fit Asus Z170-P on Cooler Master Centurion 590?
zzz123
Hello. I bought Asus Z170-P mobo. My case is Cooler Master Centurion 590.
Case:
http://www.coolermaster.com/case/mid-tower/centurion-590/
Mobo:
https://www.asus.com/pl/Motherboards/Z170-P/
Will i fit to my case that motherboard? Here are pics of my case inside and stock screws. That screws allow me to plug mobo?
Screens:
If it supports the mobo layout/size, then yes.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
