I bought my Logitech z506 5.1 surround system yesterday but i can't get my rear speakers to work. I do have a rear speaker jack on my motherboard. I got a asrock z77 extreme 4 motherboard. When i go to my realtek hd audio manager, it says there is a signal from the audio jack but there is just no sound coming from it. I already got my settings to 5.1 surround and i checked if the cables are on all right spots and it should be fine. it's not the speaker itself because i but the speakers in the other jacks and they work fine. When i go to realtek and i enable 5.1 surround i can't enable rear speakers. i can only enable side speakers. i don't know if that is the issue. but on the motherboard it says rear too. the front speakers, center speaker and sub woofer are doing great. Do i need to get a sound card or is it the software? please help me. :/:$
https://linustechtips.com/topic/588064-51-surround-doesnt-work/
LOL you have to plug the speakers into the sub. You plug all the cables in to the sub and then you plug all of your speakers into the sub.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7658934
No need to laugh, that is why he is here. For help.
I don't even know to do that...
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7658943
I did not laugh m8, but how can you miss all of that on the back of the sub?
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7658950
Hmm maybe there is something wrong with the sub then... I cant help that much more for the next 3-4 hours since I have things to do.
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7658983
"LOL" is not laughing?! I dunno, he might of not seen them. Hence why he is here for help.
13 minutes ago, NathanSwift said:
i checked every input and they work fine
Have you got another audio source to try? Like another PC?
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7659034
1 minute ago, NathanSwift said:
No i don't have that.
Are you getting any audio at all? Or just not 5.1?
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7659052
Go to Start > Sound > Then press "Properties" and look at the jack information. What does it look like?
Also, whilst there press "Configure" and look at all of the possible audio sources.
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7659074
jack information:
L R :green circle: rear panel 3.5 mm jack
RL RR :black circle: rear panel 3.5 mm jack
C Sub :orange circle: rear panel 3.5 mm jack
should be working fine if you ask me
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7659086
jack information:
Do they all show up in the "Configure" menu?
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7659091
they show up yeah but the rear speakers just don't give me sound
What if you go directly out of the PC into just 1 speaker?
Is it possible to do that? I cannot really see :D
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7659110
if you put the rear speakers into it works but just on their own spot they just won't workO.o
Hmmm, have you gone through all sound options and looked for 5.1 surround, and if so enabled all of those options?
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7659132
Just now, NathanSwift said:
yes i have surround on in windows and i have surround on in realtek hd audio manager.
Oh right. I think a Google might help 0_O
I would help, but I am kinda busy atm. Sorry :/
https://linustechtips.com/topic/588064-51-surround-doesnt-work/#findComment-7659148
