Visual studio help
Go to solution Solved by Naeaes,
There's two buttons there. When you hover over first button, it'll show the second and hide the first. When you hover over the second, it'll show the first and hide the second. Like so:
Public Class Form1
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Button2.Visible = False
    End Sub
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.MouseEnter
        Button2.Visible = True
        Button1.Visible = False
    End Sub
    Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.MouseEnter
        Button1.Visible = True
    End Sub
End Class
I ignored the middle button. That's just a Msgbox("Your message here.", ,"Title here")
 I think this is done using the "OnMouseHover" function.
Here is an example:
Private Sub Button1_Hover(sender As Object, e As EventArgs) Handles Button1.MouseHover
Dim b as Button1_Hover
b.left = 100 'pixels from the left of the screen
b.top = 110 'pixels from the top of the screen
b.text = "click for free money"
End Sub
This doesn't do everything the GIF shows but it's a good starting point
https://linustechtips.com/topic/587466-visual-studio-help/#findComment-7652620
Public Class Form1
    End Sub
    End Sub
    End Sub
End Class
https://linustechtips.com/topic/587466-visual-studio-help/#findComment-7652649
