System and Compressed Memory/System Interrupts high CPU usage
20 hours ago, GoodBytes said:The only reason why I said I would do this, is for crossing my fingers that it has improved compatibility, or bug fix if that is the reason that is specific to a small number of people that Microsoft might have fixed. It is a coin toss really. But I think it is worth the try. Personally, I am on the Fast Ring, not because of issues, I just like playing with new stuff.
Mystery solved! After weeks of Googling all over the show, I found a single post that concluded the issue is due to the physical configuration of the ODD caddy! Here's the link, but my caddy actually had a little switch. Still no idea what it does, but that's completely solved the issue. Huzzah!
http://forum.notebookreview.com/threads/hp-elitebook-8560p-wont-shutdown.655065/
