HI!!!
I'm Planning to Build the new PC.... I have 700 USD or 33000 PHP Budget.
Is this a good build? Here's the specs:
AMD FX-8350 (4.0 GHz) BLK EDITION (8,600 php)
MSI 970 Gaming Motherboard (5,050 php)
KHX318C10FB/8 8GB FURY BLACK (2,150 php
PALIT GTX950 2GB DDR5 128BIT (8,550 php
Coolermaster Mastercase 5 Full Tower Black (5,999 php) or NZXT Source 210 Mid Tower Chassis Black (2,000 php)
I Have a FSP Raider 550w Power Supply so.... no problem with the power supply. And I Have also a CoolerMaster blizzard t2 mini
Thanks.
Waddup..
Current PC SPECS
CPUAMD Ryzen 5 1600  MOBO: MSI B350M Mortar GPU:Zotac GTX 1050 Ti 4GB Mini RAM: Kingston Fury DDR4 2400Mhz Power Supply: FSP Raider 550w 80+ Silver  Storage: 3TB (2 x 1TB Western Digital Blue HDD, 1TB External HDD) CaseCooler Master.... IDK what model..
https://linustechtips.com/topic/586533-cheap-pc-build-help/
2 cases? Just get a cheap case and use the money you saved for the other parts. Get an intel i5 instead unless its massively more expensive.
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643047
I Don't know which of the two cases to pick.. What kind of I5 to pick?
Waddup..
Current PC SPECS
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643056
I5 6400 if the budget fits, otherwise i5 4460 will do.
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643088
Just search in www.pcx.com.ph.. the I5 6400 is worth 9,100 php and the I5-4460 is worth 9000 php. which is a bit more expensive than the FX-8350. They have similiar performance. If I will buy I5-6400 or I5-4460, What motherboard is good for that?? thanks
Waddup..
Current PC SPECS
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643127
28 minutes ago, zniv1216 said:
HI!!!
Thanks.
bit over budget but you get what you pay for I.E best bang for the buck
PCPartPicker part list: http://pcpartpicker.com/p/tkf2K8
Price breakdown by merchant: http://pcpartpicker.com/p/tkf2K8/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard  ($66.88 @ OutletPC)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($27.09 @ Newegg)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive  ($49.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: Gigabyte Radeon R9 390 8GB Video Card  ($299.99 @ SuperBiiz)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($27.99 @ NCIX US)
Total: $732.81
Generated by PCPartPicker 2016-04-24 07:49 EDT-0400
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643131
too expensive here in the Philippines.. cost 18,900 PHP or 404 USD
Waddup..
Current PC SPECS
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643152
For both i5s, just get the cheapest mobo that you can find with the features that you need. Give me an hour or two and i'll see what i can make with the local websites.
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643164
i'll use http://services.pcgilmore.com.ph/pricelist for the unlinked items. its abit over budget, but it'll be able to max out games at 1080p. if you can't afford the extra $14, change the sshd to a normal toshiba 1tb hdd for PHP 2300.
cpu:intel i5 6400 PHP 9050
mobo: asrock h110m-hdv PHP 3250
graphics card:msi r9 290 gaming PHP 13995
ram: KINGSTON 8GB 2133MHZ FURY PHP 1800
sshd: seagate 1tb hybrid PHP 3900
psu: your fsp raider
case:tecware raiden black elite PHP 1400
total:PHP 33395 ($714.55 USD)
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643432
Thanks.
Waddup..
Current PC SPECS
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643539
no problem. btw, press 'quote' if you're talking to one of us so that we'll know that you replied. its the arrow at the bottom of the comment pointing left.
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643581
I think will go for i5-6400 since only 10 usd or 500 php more expensive than fx-8350 .... thanks for suggesting!!! much appreciated.
25 minutes ago, Aditya0002 said:
k ,what about a r9 380x if it's cheap go for it or if not go for a gtx 960
i would  recommend a r9 380x if possible or go for second option gtx 960
I think I will go for the GTX 960.. but thanks for suggesting!! much appreciated.
Waddup..
Current PC SPECS
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643781
If it fits into your budget, get the msi 290 instead, Its vastly better than the gtx 960.
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643793
ok but I will contact the local retailer if the r9 290 is available if not i'll go with the 960.. pcgilmore is too far away from our home. thanks
Waddup..
Current PC SPECS
https://linustechtips.com/topic/586533-cheap-pc-build-help/#findComment-7643850
