Using python class as struct?
Go to solution Solved by Azgoth 2,
There's actually no need for getter and setter functions in Python--that functionality is already built in to classes, so writing those functions in is completely unnecessary.  Using your class GROUPS,
foo = GROUPS(var1, var2)
# This does the exact same thing as foo.getGName():
foo.GName
# This does the exact same thing as foo.setGName(var3):
foo.GName = var3
Other object-oriented languages do use and require setter/getter functions, but Python is not one of them.  Writing them just duplicates functionality that's already there.  So your definition of GROUPS doesn't need any of the set/get functions:
class GROUPS:
    def __init__(self, gname, ips):
        self.GName = gname
        self.IPS = ips
So I'm making a program for one of my classes. I need to make something like a struct from C++ in python but I don't know python well enough to know how to do that.
I need to store:
  • Group name (only one name)
    • Get group name
    • Set group name
    • Search for group name to add/remove/find all IP's associated with said group
  • List of IP's
    • Be able to list off all IP's
    • Add/remove individual IP
    • Size of list (Use len()?)
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/585940-using-python-class-as-struct/
class testclass:(object)
	def __init__(self, var1, var2):
		self.var1 = var1
		self.var2 = var2
	def getVar1(self):
		return self.var1
	def setVar1(self, var1)
		self.var1 = var1
	def getVar2(self):
		return self.var2
	def setVar2(self, var2)
		self.var2 = var2
Here's an example of using python classes with getters and setters, the rest I leave as an exercise to the reader
		self.var1 = var1
		self.var2 = var2
	def getVar1(self):
		return self.var1
		self.var1 = var1
	def getVar2(self):
		return self.var2
		self.var2 = var2
So I must be doing something wrong... It keeps giving me errors. Here's the class I made:
class GROUPS:
    def __init__(self, GName, IPS):
        self.GName = GName
        self.IPS = IPS
    def getGName(self):
        return self.GName
    def setGName(self, GName):
        self.GName = GName
    def getIPS(self):
        return self.IPS
    def addIP(self, IPS):
        self.IPS.append(IPS)
    def remIP(self, IPS):
        self.IPS.remove(IPS)
And when I do this code....
def CREATEGROUP(client,group):
    newGroup = GROUPS(group,client[0])
    newGroup.setGName(newGroup,group)
    newGroup.addIP(newGroup,client[0])
    return newGroup
It says that I'm passing 3 args instead of 2? client[0] gives the IP using simple sockets.
Any idea what I'm doing wrong?
is CREATEGROUP it's own function outside of the class? remember you have to create an instance of the groups class before you can use it. like this:
<your group class goes here>
testgroup = GROUPS(group, clients)
testgroup.getGName()
testgroup.setGName("testgroup1")
Don't forget the supporting functions needed. If you like send the complete code in an attachment and I will run it to see what guidance I can offer on solving the issues
Sent it in messages
Your addIP function only takes 1 parameter but you're passing it 2.
No?
No?
self isn't a parameter, it's automatically set to the object before the dot.
So, newGroup.addIP(client[0]) actually calls addIP(newGroup, client[0]). Just like C++ but in C++ the "self" parameter is hidden.
1474412270.2748842
Cool. Didn't know that. Thanks!
foo.GName
foo.GName = var3
class GROUPS:
        self.GName = gname
        self.IPS = ips
