So I bought this from amazon:
https://www.amazon.co.uk/gp/product/B00NGD2GQE/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
but the driver disc was missing so does anyone happen to know where I can find the software as google is not helping me :/
thanks in advance and by the way it is noisy as hell, gives a good gust and I wouldn't recommend apart from being able to program in random insults to passer byes.... :P
SODIAL(R) USB Powered Desktop LED Programmable Message Fan
CPU:                Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor
Graphics:         Inno3D GeForce GTX 980Ti Hybrid Black Edition 6144MB GDDR5 PCI-E
RAM:              Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz
Case:                Phanteks Enthoo Evolv ATX Mid Tower Case - Black (3x 140mm Phantek fans)
MOBO:            Asus Maximus VIII Hero Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Boot SSD:        Samsung 250GB 840 EVO SSD 2.5" SATA
Game SSD:      Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive
CPU Cooling:  Overclockers UK & SilverStone - 120mm FQ121WC Watercooling Radiator Fan x 2
                       Asetek 240mm 570LX
PSU:               Corsair 750M Semi-Modular 80 Plus Gold rated
Monitor 1:       Sony BRAVIA KDL32W705BBU Smart 32" LED TV
Monitor 2:       Samsung 24" S24C300
Keyboard:        Razer Blackwidow Chroma
Mouse:             Roccat TYON
Speakers:         SBS2112 with Bluetooth
Headset:           Turtle Beach Elite 800 Stealth
https://linustechtips.com/topic/585875-can-anyone-help/
                       Asetek 240mm 570LX
Mouse:             Roccat TYON
https://linustechtips.com/topic/585875-can-anyone-help/#findComment-7636942
3 minutes ago, GreezyJeezy said:
both links are coming up as a virus and being removed by my norton antivirus....is this normal or.... :S
                       Asetek 240mm 570LX
Mouse:             Roccat TYON
https://linustechtips.com/topic/585875-can-anyone-help/#findComment-7636958
1 minute ago, GreezyJeezy said:
Do you have an as locker so you get the right links
an as locker?! not sure what you mean, I clicked both these links below:
                       Asetek 240mm 570LX
Mouse:             Roccat TYON
https://linustechtips.com/topic/585875-can-anyone-help/#findComment-7636971
That's what I did
I have pulled it from quarantine and restored it so will try to program now and shall see if it accepts profanities ;)
                       Asetek 240mm 570LX
Mouse:             Roccat TYON
https://linustechtips.com/topic/585875-can-anyone-help/#findComment-7636988
8 minutes ago, GreezyJeezy said:
That's what I did
I cant seem to get the software to connect to the fan....just say USB disconnect.... any trick to it or?!
                       Asetek 240mm 570LX
Mouse:             Roccat TYON
https://linustechtips.com/topic/585875-can-anyone-help/#findComment-7637008
16 minutes ago, GreezyJeezy said:
That's what I did
Right I found this and it works like a charm and also has a few more extra bits so something you may want to try
https://drive.google.com/file/d/0B229lbXhhSKSM29Ddmx1dDhlMm8/view?pageId=101208565940491698739
(Its a google doc zip file so download, scan and then unzip for software and english instruction set :)
also cleared by virus scan myself and no issue like the other program so that one is out and this on is in! time to start fiddling :)
Thanks by the way!
                       Asetek 240mm 570LX
Mouse:             Roccat TYON
https://linustechtips.com/topic/585875-can-anyone-help/#findComment-7637040
Guest
