1 hour ago, KidneyBean said:
When did you plan out this build? The hardware is last gen. you'll have a much better experience using current hardware and should have no problem staying within your budget.
that hideous heatphone though.
and the 750ti
AND THE 2X4 GB RAM
should go 1x8gb
https://linustechtips.com/topic/585386-first-build-need-help/#findComment-7632552
I think this would be a better place for you to start http://ca.pcpartpicker.com/p/JRph6h
This would be a good route for upgrading the gpu and cpu later I would also recommend getting the cheapest keyboard you can find until you can save up a bit of cash.
I didn't include an OS because you should check this out
https://linustechtips.com/topic/585386-first-build-need-help/#findComment-7632630
