3 minutes ago, Technozo said:
Are power extensions needed when you build a PC or can you use your PSU cables and not have a problem with length. Here's my budget PC if you need the specs: http://pcpartpicker.com/p/LRpHvK
PSU cables are normally okay for ATX case sizes, extensions are normally only used for server boards or sizes larger than atx
https://linustechtips.com/topic/584878-power-extensions/#findComment-7627117
