Do you guys know of any tool to throttle frame rate?
If a cpu doesn't have the muscle to render a game at 1080p at 60fps, no sweat at 30fps, and it seems like it will do fine at 45 fps, is there a tool that will set the game's frame rates at 45 fps?
Don't suggest hardware upgrades because the owner has no money to upgrade.  Throttling tool should be free.  Afterburner?
G3258 oc 4.2ghz
GTX 650ti
GTA5
Stutters at 60fps
30 fps no sweat
Logging on fps shows the average is at 45.  Throttling back and forth between minimum and max causes stuttering.
I'm guessing if it can be throttled at the average of 45 fps, it would run better.
https://linustechtips.com/topic/583704-frame-rate-throttling/
riva tuner statistic server.... its free and can cap frame rates i use it to cap mine at 144
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/583704-frame-rate-throttling/#findComment-7614983
