Hello fellows!
I was following the JayzTwoCents gpu oc guide with my EVGA 980ti Hybrid. SInce it's water cooled I want a better free performance. So I installed Benchmark Vallet wich comes with the EVGA CD Driver. Also MSI Afterburner. Decided to follow the instructions so I started with the Core Clock. 150mhz plus. Let the core voltage at 0. And after a while running BV I noticed that my 980ti is running at 1680mhz (with teh 150mhz plus oc) :0 Is that posible?! Also my highest temp was 48c :o
(Note; I'm running Push/pull config)
https://linustechtips.com/topic/583593-am-i-right/
39 minutes ago, RadiantLc1 said:
Hello fellows!
It's called GPUBoost 2.0. Makes you achieve insane frequencies, whether they're actually achievable or not.
Anyways, remember to run multiple tests. Firestrike, Heaven (Valley has never detected a failed OC with me, but you could try that one as well). My favourite is geneferocl, which easily detecs fail OCs well before other programs I've tried, but it's MUCH more strict than your regular benchmark / game, so I'll only bother explaining it if you are after 100% stability.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/583593-am-i-right/#findComment-7614040
