Posted April 16, 2016 Hiho, I'm looking for braided cables for RM1000 GOLD corsair power supply, but I can't find them anywhere online. I'm also not sure if I will get all of the necessary cables for e.g. SLI etc. Main PC: CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88 CPU Voltage: LLC6 1.43V Cooled by: Supercool Direct Die 14th gen full nickel Motherboard: Z790 ASUS Maximus Apex Encore RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled GPU: RTX 5090 Palit OC with Alphacool Core Waterblock Case: TT P3 Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup) PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and 2x ASUS XG17AHP 240hz 17" Fan Controllers: 6x AquaComputer Octo Cooling: Three Custom Loops: 1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant 2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant 3x 360mm PE EKWB CoolStream 3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case 2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe 1st Laptop: MSI Titan HX18 Dragon Edition, RTX 5090 175W, Core Ultra 285HX, 128GB of RAM @5600Mhz / 96GB @6400Mhz 8TB of NVMe - GPU and CPU with LM on, Llano V12 2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12 3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe HTPC: CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock, Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4 WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers: 1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM Link to comment https://linustechtips.com/topic/582644-braided-cables-for-rm1000/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
