Tonight I've had a blue screen whenever I try to play a game, I have Windows 10, and the code is THREAD_STUCK_IN_DEVICE_DRIVER and after a bit of research I found that flashing the bios fixed the problem, and whilst I was doing that (GIGABYTE Z-97 MOBO) through the software, it blue screened in the middle of flashing, and now my PC is stuck in an endless loop of constantly Turing off and on every three seconds. I have no idea what to do, please help.
https://linustechtips.com/topic/582539-need-help-asap/
If it crashed during flashing, you just bricked your board. How could it have blue-screened during flashing, though? You didn't do it through Windows, did you?
Check to see if your motherboard is a dual BIOS board. If it isn't, you need to buy a new board.
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604239
This should be posted in troubleshooting. Is there a second bios on your board you could switch to?
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604240
I was updating it through the program in Windows, and it blue screened. It is a dual bios chip board, I need someone to walk me through what to do. Can you call please?
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604243
2 minutes ago, Joshua Bean said:
I was updating it through the program in Windows, and it blue screened. It is a dual bios chip board, I need someone to walk me through what to do. Can you call [DELETED] please?
Please delete your phone number before someone randomly calls you.
Which motherboard is it?
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604244
Why does no one read the descriptions of the sub-forums
Read it please then come back and say what you were saying
Edited by LynxThe1st
added pic
Well, now you're reading this, I might as well inspire you with a deep quote
If you fall, I'll be there
             - Floor
so inspiring, so deep, the feels ;-;  THE FEELS ;-;
Newer Build which I'm gonna buy when I haz moneyz
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£0.00)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  (£25.98 @ Novatech)
Motherboard: MSI B85-G43 GAMING ATX LGA1150 Motherboard  (£78.10 @ Amazon UK)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£0.00)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£29.76 @ Ebuyer)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£0.00)
Video Card: MSI Radeon R9 380 4GB Video Card  (£179.99 @ Amazon UK)
Case: Corsair 780T ATX Full Tower Case  (£149.99 @ Amazon UK)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£70.97 @ Amazon UK)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For £0.00)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£59.00 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£24.99 @ Amazon UK)
Keyboard: Corsair K95 RGB Wired Gaming Keyboard  (£184.99 @ Amazon UK)
Total: £803.77
somethings says '£0.00' because I already bought them
probably best remix out there
If I follow you, consider your self lucky, I rarely follow people and when I do it's either because
1) I look up to you
2)I like your picture
3) Or you have an epic ass rig (40 titan x's 9 6700k's clocked at 29GHz that is what I call a epic ass rig, but no one has that soo...)
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604246
Just now, Joshua Bean said:
Well I need someone knowledgable to walk me through what to do, and frankly, I don't care if someone randomly calls me. That happens all the time.
What motherboard is it?
Edit: Got it. Give me a moment.
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604250
Alright, so it appears your board has Gigabyte's dualBios via UEFI, and not a physical switch on the board. The only thing I can suggest is letting it boot loop and see if it recovers eventually. Otherwise, you might want to consider a new board.
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604266
But it's a dual bios board...?
Are those my only two options?
Can someone explain what the hell happened?
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604271
You were attempting to flash your BIOS in an attempt to fix your issue. You did so through software on Windows, instead of on the board itself through the Flash Utility in your BIOS. During this, your PC crashed, and your BIOS became corrupted, throwing your PC into a boot loop.
If your board has a physical switch on it for the dual BIOS, switch it. However, my limited research returned no such results for something of the like on your board. If it does, switch it. If it doesn't, let it boot loop for awhile and see if anything happens.
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604280
If it doesn't have a switch, what's the point of having dual bios?
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604288
Because, unlike GPUs with dual BIOS for overclocking, your board has it as a backup. So it's a failsafe. I'm suggesting leaving it in boot loop to initiate a recovery.
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604292
2 minutes ago, NonaHexa said:
I honestly have no idea. Could take two minutes, could take thirty. I've never had to do it, personally. Just know that there's no harm in letting it go.
Well to me it is because I'm 17 and money doesn't come easy.
What does clr_cmos do?
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604306
That won't do shit
Resets BIOS Settings to default
edit: holy mutherfuckig shit this editor, I can't even finish a post without it posting
Anyways it just resets BIOS settings to default which I doubt will do shit since you faced a blue screen not something too the actual BIOS(S)
             - Floor
Total: £803.77
1) I look up to you
https://linustechtips.com/topic/582539-need-help-asap/#findComment-7604308
