Difference between these
Go to solution Solved by Wolther,
Yes. the most expensive one has
Height & Pivot adjustable
10-bit color depth
Adobe RGB 99.5%
Speakers
2nd most expensive has
a certified gold rating
and the least expensive has thunderbolt
