In my house, the network is really bad in one corner of the house. We've used repeaters, but I want to come up with a more permanent solution. Part of the reason is because our router is near our computers, which is in a corner of the house so it does not reach. I was thinking of a business grade wired router and UAP AC Pro (Link: https://www.ubnt.com/unifi/unifi-ap-ac-pro/ ), but I would love to hear if there is A. a better option or B. If that solution is way overkill. We also live in a condo, so there is a ton of interference. Thank you!
https://linustechtips.com/topic/581934-network-trouble-please-help/
1 minute ago, transposedmessenger said:
If it's the interference, make sure you have dual-band and that it is enabled. Maybe you could upgrade to tri-band? There are plenty of consumer grade routers that "get the job done" for what your situation sounds like for $100-200
We have Apple's Airport Extreme, I don't know what model, but it has dual band that is enabled. Part of the problem is also the placement, and with an AC I might be able to have it closer to the center of the house. I will definitely look into some other routers too. Thank you!
