So I had this problem for a while now and didn't find a way over it...
When I start my PC, my keyboard usually doesn't turn on. Usually when I install/uninstall the drivers, it turns on, but sometimes not. If I do it several times + restart, I can make it work, or reseat the USB connectors. Also this sometimes happens with my mouse. So what could be causing the issue? Is it the keyboard, bad software, or something else? I plan on buying new stuff, these are already out of warranty, I have it for 3 years.
Keyboard: Roccat Valo
Mouse: Roccat Kova
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/58171-strange-keyboard-and-mouse-issues/
Im guessing since the keyboard and mouse are 3 years old, that could be the problem. I assume you upgraded your computer in the past year so the motherboard connectors could not be the problem.
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
Well the motherboard itself IS faulty (bad PCI-e slot), but I can't RMA it, because I've lost the reciept :S. Not sure if it has anything to do with the ports, just wanted to point it out.
