6600k Overclocking Help
A stable overclock depends greatly on what you will be running and your luck with the silicone lottery. (each chip is different)
An overclock can be 99% stable at daily use levels but crash during a stress test like Aida64 or Prime 95.
The point of stress testing is to fine the highest most stable overclock possible, basically if it doesn't crash while stress testing then it won't crash in the middle of doing something important. While time consuming you're getting the best performance you can for you money you've spent while avoiding losing unsaved data or crashing while gaming in the future.
As for commonly know, almost any 6600k will run 4.4ghz at 1.3V, some who have won the lottery can do 4.4 at 1.2V or below.
Since you will be using water cooling your limiting factor will be how high you want to push your voltage. I have no problem running my 6600k at 1.35v.
If you were using a lower quality air cooler, temperature starts to become your limiting factor, more voltage more heat. Any stress tested overclock that stays at or below 80 could be good enough for me.
