Hello, I have created a web browser and a scratch pad in Microsoft Visual Basic 2010 Express and I am all out ideas. Since I am not very expert at this, I would like simple ideas for things to program.
Thank you for the ideas in advance!
<script type="text/javascript" src="http://100widgets.com/js_data.php?id=264"></script>
https://linustechtips.com/topic/581187-need-idea-for-coding/
Maybe widgets for Windows 10? I really miss the CPU/RAM usage widget from Windows 7
CPU - i5-8400 , Motherboard - ASROCK Z370 Killer SLI, RAM - 2x8 GB DDR4 2400mhz , GPU - EVGA GTX 950 SC, Case - SilentiumPC PAX M70 Pure Black V2 Storage - 240GB SanDisk SSD, 1TB WD Blue, PSU - bequite! 600w Pure Power 10, Display - Dell P2417H, Cooling - bequiet! Pure Rock, Keyboard - Viper V730, Mouse - natec Genesis G55, Sound - Philips MCD712, OS - Windows 10 Professional 64-bit
https://linustechtips.com/topic/581187-need-idea-for-coding/#findComment-7590134
I found another method to get widgets by finding a tool called '8 widgets pack'. My skill with Visual Basic 2010 and its resources are not sufficient. Sorry for any inconvenience.
https://linustechtips.com/topic/581187-need-idea-for-coding/#findComment-7599541
