Wait, overclockable PSU? That's awesome.
Could you really overclock a PSU?
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
They're a horrible Chinese made brand of psu's. stay away
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
Nope they are made by Super Flower which is right up there with Seasonic, well at least the Lazer one I am looking at is.
http://www.tomshardware.com/reviews/power-supply-oem-manufacturer,2913-7.html
Then I must be mistaken
I meant this
It's not really "overclocking". It just used for marketing to say that the protection to shut the unit off is set higher to allow it to function as a 650w Gold unit.
Nonetheless, the Kingwin LZP-550 is indeed an excellent premium unit based on the Golden King platform from Super Flower.
In my book, Kingwin is one of those brands I would completely stay away....but this "lazer product-line....just wow, amazing. The soldering done in the PCB's were pretty friggin' amazing (though the soldering on the modular connection PCB could be better). Those are definitely up on the same level as the 80 PLUS Platinum units from SeaSonic / Antec / Corsair.
As @quan289 said, the "overclock to 650W" is a marketing gimmick.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
