I want to make my first gaming (games like the elderscrolls, battlefield, gta), photoshop and video editing pc this summer holiday but I need some help.
This is the system I want to make: http://au.pcpartpicker.com/p/jJfZnQ
But can I better wait for the gtx 1070 and need I a other motherboard then or not?
I hope that you guys can help me whit my build and give some commentary where needed.
https://linustechtips.com/topic/580107-first-gaming-pc-build/
welcome to the forums :P
remember to quote or mention the person you're replying so they get a notification
its best if you can wait, you wont need a new motherboard as pcie is a standard
about your build
1) you should consider getting an r9 390, its better than the 970
2) you should get a better PSU (in term of model), 500W is fine, but get 550~650W is you wanna overclock your gpu
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/580107-first-gaming-pc-build/#findComment-7579742
It looks fine to me but if you have a little bit more dosh to spend on the computer I would try to go for a "K" series CPU and a Z170 motherboard so that you can overclock in the future and get more performance out of the little beast in the future.
But @Moonzy said it best, PCie is a standard.
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
https://linustechtips.com/topic/580107-first-gaming-pc-build/#findComment-7579752
Video editing and photoshop?
PCPartPicker part list: http://au.pcpartpicker.com/p/HCd2qs
Price breakdown by merchant: http://au.pcpartpicker.com/p/HCd2qs/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($365.00 @ CPL Online)
Motherboard: MSI B85M-G43 Micro ATX LGA1150 Motherboard  ($95.00 @ Umart)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($97.00 @ IJK)
Storage: Intel 535 Series 240GB 2.5" Solid State Drive  ($108.00 @ IJK)
Storage: Toshiba  2TB 3.5" 7200RPM Internal Hard Drive  ($93.00 @ IJK)
Video Card: MSI Radeon R9 390 8GB Video Card  ($509.00 @ Centre Com)
Case: NZXT S340 (White) ATX Mid Tower Case  ($105.00 @ PCCaseGear)
Power Supply: SeaSonic 550W 80+ Gold Certified ATX Power Supply  ($99.00 @ Umart)
Total: $1471.00
Generated by PCPartPicker 2016-04-11 22:35 AEST+1000
1231v3 is what you want if so.
https://linustechtips.com/topic/580107-first-gaming-pc-build/#findComment-7579804
