650D front fan replacement
Solved by Bluejay0,
hmm will have to have a look around for this cant find it on UK sites
If you cannot find it, the Spectre is actually a good choice. Both are great fans so which ever you can get, is still a good option!
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
