I need your help,so basically I tried to watch a video,but I can't as soon I get in the link,the video appears and it dissapears.
Here are the pictures ive done.
It looks like this first:
Then after 1-2 seconds it looks like this:
I had to use diffrent sites to upload images because I couldnt click "Upload Images" on few website,even these ones too,I had to refresh couple of times. Pls send help,
And I cant click these buttons same as "Upload images" or "Upload" on anything,or idk I cant edit my profile too cus the buttons doesnt work,Internet is fine.
And I am sorry if I missed the board,because im upset. Please help me,tnx.
https://linustechtips.com/topic/579553-i-need-help-asap/
Check Chrome extensions for anything malicious.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/579553-i-need-help-asap/#findComment-7574472
Your browser maybe hijacked by some adware, which i have experienced before...
Try other browser to see if its affected...
-or-
Try to reset Google Chrome:
  1. On the latest version of Google Chrome, click on the Customize and control Google Chrome button > Settings.
  2. Click on Advanced Settings.
  3. Scroll down to the bottom of the page, until you reached the "Reset browser settings" section.
  4. Click on Reset browser settings
https://linustechtips.com/topic/579553-i-need-help-asap/#findComment-7575281
-or-
Not only in Chrome,even in Mozzila,IE,and Opera. And btw im using Windows 10,forgot to mention it above.
https://linustechtips.com/topic/579553-i-need-help-asap/#findComment-7575296
Have you tried to reset chrome?
Hmm, maybe something interfering with your connection...
Try using proxy
  1. Open http://vpnbook.com/webproxy
  2. Type www.youtube.com, then hit enter
  3. Play a video
  4. Observe
Or try to use VPN...
If it still didn't show any sign of video player (even a sign that the video cannot be played), then refreshing/resetting your PC may be the quick but painful solution
https://linustechtips.com/topic/579553-i-need-help-asap/#findComment-7575369
Try using proxy
  3. Play a video
  4. Observe
Youtube works fine,but the streaming videos doesnt,like the website of movies and other things..
https://linustechtips.com/topic/579553-i-need-help-asap/#findComment-7575771
