Python - need help with 'chr' built in function
So I have this keylogger which is supposed to take the event.Ascii value which is an integer and translate that into a character by using the chr function and then write it into a file. Well it's writing the file but not as I expect, I'm getting these weird symbols instead... you can see the output below:
PS I've simplified the code for viewing / testing purposes, I took out the file read / write part to narrow down the problem.
Code: http://ideone.com/OrXK6E
My output: http://imgur.com/fdD0W3S
Thanks!
https://linustechtips.com/topic/579481-python-need-help-with-chr-built-in-function/
Probably a translation error, the integer should be the decimal that correlates with the hex character, e.g.,
>>> letter
'A'
>>> ord(letter)
65
>>> chr(65)
'A'
so if the ints you're running chr() on aren't in the range of 65-125, then that's probably why
>>> letter
'A'
>>> ord(letter)
65
>>> chr(65)
'A'
Yeah that makes sense, but why wouldn't my keyboard input produce an integer value between 65-125, I mean realistically it should since were basically translating it from its Ascii input to it's corresponding character.
>>> letter
'A'
>>> ord(letter)
65
>>> chr(65)
'A'
OK, after further testing it turns out you're right, my Ascii values are not correct for some reason and they do not fall in between the 65-125 range... do you have any idea why this might be?
