Project : Icons
Go to solution Solved by GER_T4IGA,
It is screensaver > settings > then it says use pictures from (for me it says pictures here) and on the right of that is a "search" or "select" (sry if have to translate from my language)
guys I need help,You guys know the screen saver that windows has right?
Well I dont like that bearly options that it has.
What I want to do is basicliy have the icons and task bar to just hide themselves Untill I do a funcion on the pc like clicking the mouse or just clicking the keyboard,Thus haveing my awesome wallpaper being shown off when im not touching the computer for a set amount of time.
problem is: I suck at codeing and wasnt able to find something that would do that at google.
Edit:sorry for wrong section how do I move?
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
    Thermaltake Core V21
  • Storage
    1TB HDD, 700gb HDD, 320gb HDD and 256gb SSD
  • PSU
    Corsair CX600
  • Display(s)
    Flatron L1960TR , MAG MS776I , ViewSonic VA903m ( all of them are 1280x1024,dad found em) and a Fujicom FJ-32V TV
  • Cooling
    1 200M front fan, and unknowen CPU tower(low profile)
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
    Jamo E 4 CEN, Jamo E470 and Jamo E410 with a KENWOOD S505D
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/579160-project-icons/
no thats when people remove their mice from the taskbar,I dont like that,I want that lets say 30 minutes of me not useing the pc will just show my desktop picture,Tough they change and IF I would use the same album of photos it would repeat itself,which is the problem for me entireliy
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/579160-project-icons/#findComment-7570445
There is an option to show "your photos" or you can specifically select single photos. Chose your background as the single photo to be displayed, pretty much done.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/579160-project-icons/#findComment-7570457
3.Use
https://linustechtips.com/topic/579160-project-icons/#findComment-7570468
Can you mark this solved if it is? Or is it not? Can I still help you anyhow?
3.Use
https://linustechtips.com/topic/579160-project-icons/#findComment-7570610
it is not,Becuase I dont want to actually use a wallpaper,I want for the GUI of windows to just hide itself and when I use my PC again it will turn back on,since I want the same imege from my themes to keep going.
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/579160-project-icons/#findComment-7570637
1 minute ago, GoodBytes said:
It is possible to do. but there is no software that does this. So if you know programming, you can build something that does that.
and I dont...well I guess il mark it as solved since I am sure no one will make a software just becuase I posted on a forum,thanks for the help tough :D
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/579160-project-icons/#findComment-7570660
uhm..How do I mark solved?
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/579160-project-icons/#findComment-7570667
I still don't see the difference between what you asked for and what i described. If you don't turn on the "return to login screen" option what will happen when you move the mouse will be exactly what you described except for 1 to 2 frames of black in between.
3.Use
https://linustechtips.com/topic/579160-project-icons/#findComment-7570713
ok well let me explain to you,the screensaver chooses the photos that is in a folder of yours.
The problem is for me:I want it to use the exact same picture as my desktop theme that has 385 Photos.
I dont want it to reset to the first one as they are numbered.
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/579160-project-icons/#findComment-7570776
Ok, now I see your concern. Sadly it is so specific that I can't help you.
3.Use
https://linustechtips.com/topic/579160-project-icons/#findComment-7570817
On the post that is the answer to your question, click on the check mark icon, right before the "!" triangle button. Once you do, the post color will change to green, and appear also at the top of the page.
https://linustechtips.com/topic/579160-project-icons/#findComment-7571032
