Fan Speed
Go to solution Solved by Praesi,
Buy a Fan Controller.
Hi guys i am curious about it and i can't find a way to reduce the speed of my fans ..
I have stupid Motherboard and all of my fan headers are used up by the watercooling fan and pump
and all my other case fans like 2 on top 1 front and 1 on the back of the case are connected with the power supply molex 4 pin
and my pc is actually really loud.. not that it is bothering me but is there any way that i can make those fans spin slower ? i doesn't matter if it will be a permanent solution my pc is runnin on pretty decent temperatures anyways.
Any advice will be welcome :)
https://linustechtips.com/topic/578515-fan-speed/
you cant control it if you connect it directly to the psu
what you can do is buy fan controllers (normally voltage controlled) or just buy LNA (low noise adapters)
if you wanna control it with software, you can get PWM fan hub or fan splitters
edit: if you opt for fan splitters, make sure you dont exceed the maximum wattage your fan header can provide, or you might burn the header
refer to the motherboard manual, a normal fan header should be able to power 2 to 3 fans atleast
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/578515-fan-speed/#findComment-7563865
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/578515-fan-speed/#findComment-7563947
