Hello i have a Lenovo G40-30 laptop and my hdd is dead (lagging on windows start screen, hearing heavy clicks and not opening on other systems as secondary drive) so i bought a new hdd put it in downloaded windows 7 made a bootable usb drive but when i boot it says "Device has been blocked by the current security policy" and it won't let me do anything what can i do? is there any other way to do this?
https://linustechtips.com/topic/578201-lenovo-laptop-problem/
copy the bad hdd over to the new hdd
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/578201-lenovo-laptop-problem/#findComment-7561374
6 minutes ago, kendokas said:
but my old hdd is dead it can't be read... :/
The laptop is still under warranty right? if yes give them the laptop back and say that the hdd is dead and they will fix it for you since it's under warranty
https://linustechtips.com/topic/578201-lenovo-laptop-problem/#findComment-7566668
i think the warranty ended if i could i would have done that is there any other way to solve the problem and install windows?
https://linustechtips.com/topic/578201-lenovo-laptop-problem/#findComment-7578932
Check your BIOS settings. Did it come with Windows 7 or 8/8.1? If Windows 8/8.1, before installing 7 make sure you change the boot mode from Legacy to UEFI in BIOS.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/578201-lenovo-laptop-problem/#findComment-7578990
And how do i do that? i mean how to open the bios settings in this laptop i tried F12 and it doesn't do anything :S
https://linustechtips.com/topic/578201-lenovo-laptop-problem/#findComment-7594908
Try F2. And if spamming does not work, try holding it down instead.
EDIT: This should be useful
https://support.lenovo.com/documents/yast-3jwkjx
https://linustechtips.com/topic/578201-lenovo-laptop-problem/#findComment-7594916
tried everyone of these but it's not working and on my model it says something about a blue Access IBM button but it's not on my laptop.. any other ideas please? i just want to put a new hdd that i bought and format it to Windows 7 but my old hdd is broken so i can't make the recovery backup for the windows and i can't access BIOS.. so what can i do?
https://linustechtips.com/topic/578201-lenovo-laptop-problem/#findComment-7615375
