Hi Everyone,
I'm trying to get a SQL query to work in a c# windows forms application but I keep getting data mismatch errors. I'm trying to search through records that contain the autonumber value from a different table as their foreign key so for example:
BuildingID - the primary key
BuildingName - some name
OrgID - the foreign key I'm trying to search by
The part that I can't get to work is where I have a long variable. I have tried Single, Double and int but I can't get it to work with the query
just for context the attached picture of the code is searching a database for information on hardware and displaying it in to a table. Then the second part is finding building name values for a combo box and it's picking these out by the OrgID value then inserting them in to the combo box.
Sorry I can't put my code in the post for some reason even with code tags it blocks my post
any help getting this working is greatly appreciated
thatOCGuy
https://linustechtips.com/topic/578119-sql-help/
