I need to find a good CPU cooler that's smaller then a Hyper 212 Evo (My case is just barely too thin by a Centimeter to fit a 212 Evo) that would be able to handle a AMD A8-7650K and handle the workloads of video editing, video rendering, and gaming.
Computer I'm sticking the cooler in: http://pcpartpicker.com/user/SuperM4Tanker/saved/gRdBD3
Processor the cooler is for: http://pcpartpicker.com/part/amd-cpu-ad765kxbjabox
Case the cooler is going to fit in: http://pcpartpicker.com/part/cougar-case-spike
And here's the ram the cooler has to clear in terms of if it will fit: http://pcpartpicker.com/part/gskill-memory-f312800cl9d8gbxl
https://linustechtips.com/topic/577687-need-good-cpu-cooler-for-computer/
4 minutes ago, SQZY98 said:
Believing partpicker.com, the Hyper 212 should fit. As Sakkura has already said, i´d recommend the cryorig h7. Or do you want to go with a top-blow CPU cooler?
I already tried the hyper212 in that case when I tried putting my intel processor in that case and I don't mind what type of CPU cooler it is as long as its not one of those exotic looking coolers and is better then the stock cooler
The 212 Evo should fit. It's been done many times before.
18 minutes ago, Nacho Marco Segui said:
Scythe Kotetsu
The Kotetsu is taller than the 212 Evo.
the evo won't fit I already tried it with a evo I already own
Try again. It should fit just fine unless you're using a fan on the side panel. https://pcpartpicker.com/builds/#h=7&e=244
I can't really try again now because I have my 212 evo mounted in my intel machine I think I might try the cryorig h7
