35 minutes ago, kyle.schofield said:
Thoughts on this, i am a first time builder with a budget of about $1000AUD, i plan to use it for minor gaming and just as a general PC.
What you listed there is over 1000 AUD so I'm going to assume you're a bit flexible (which is good)
Here's what I put together:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($335.00 @ IJK)
CPU Cooler: Cooler Master Hyper T4 70.0 CFM Rifle Bearing CPU Cooler  ($33.00 @ Umart)
Motherboard: MSI B150M MORTAR Micro ATX LGA1151 Motherboard  ($139.00 @ Umart)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($48.00 @ IJK)
Storage: Samsung  250GB 2.5" Solid State Drive  ($123.00 @ Centre Com)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ Centre Com)
Video Card: Gigabyte GeForce GTX 960 4GB Video Card  ($299.00 @ CPL Online)
Case: Cooler Master Force 500 ATX Mid Tower Case  ($52.00 @ CPL Online)
Power Supply: Corsair VS 550W ATX Power Supply  ($67.00 @ IJK)
Total: $1165.00
Generated by PCPartPicker 2016-04-06 16:15 AEST+1000
I stuck in the 6600k since it's only a bit more than the 6600
The case is really up to you, I stuck in the CM Force 500
Also, you can't use DDR3 memory with skylake (well you can but very few motherboards support it)
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/577467-first-time-builder-help/#findComment-7552921
