https://linustechtips.com/topic/577079-pre-built-pc/
1 minute ago, PaPa Smurf said:
Wait, did you already buy this? OR are you looking into buying it?
https://linustechtips.com/topic/577079-pre-built-pc/#findComment-7548112
5 minutes ago, PaPa Smurf said:
r9 380 would be a better GPU for similar price
https://linustechtips.com/topic/577079-pre-built-pc/#findComment-7548139
Drop the sound card, the z170 board for a cheaper board, the hyper 212x and 8gb of ram, then get an r9 390 instead since these parts are not necessary.
https://linustechtips.com/topic/577079-pre-built-pc/#findComment-7548151
