Virtualized VMWare box with pfSense and linux dns/hosting box
@tv15dsi Bridging isn't required for what you want. You create two virtual switches in ESXi, one for internet and one for local LAN. On the pfsense VM add two virtual NICs, one on the internet virtual switch and one on the LAN switch. For the debian VM add a single NIC on the LAN virtual switch and set the default gateway to the IP of pfsense LAN NIC.
Physical cabling wise the NIC assigned to the internet virtual switch goes to the router and the NIC assigned to the LAN virtual switch goes to your switch. If you only have a single all in one switch router this is still fine, both server NICs can physically plug in to the router just use different IP subents for the router/pfsense internet interface than the internal LAN subnet. Not a perfect setup but it will work.
