How do i manually set the h220 pump speed. All i see in bios is profiles ex. silent, normal  etc.......
mb: asus p8z77-v lx
| 3570k @ 4.5 | swiftech h220 ordered after patent issues | EVGA 660ti SC 3gb | 8gb gskill ripjaws | Asus p8z77-v lx | Corsair Ax 750 | Asus Xonar DS | Corsair C70 white | CM quickfire rapid mx browns | G500 |
https://linustechtips.com/topic/57658-h220-pump-speed/
why would you want to have it on manual. why run the pump harder then it needs to?
Let it be controlled by the motherboard. it will go to 3000rpm when it needs to.
Old Rig | Cpu - Intel Q6600 @ 3.5Ghz | Cooler - Cooler Master Hyper 212+ | Mobo - Asus Rampage Extreme | Ram - 8GB OCZ Gold 1600mhz | Gpu - 2x Asus DK Radeon HD 4870 1GB (Crossfire) | Psu - Corsair TX750W | Case - Thermaltake Element G
New Rig | Cpu - Intel 4770K @ 4.5Ghz | Cooler - Swiftech H220 | Mobo - Asus Z87 Deluxe | Ram - 16GB Kinston Hyper X Beast @ 2400Mhz | Gpu - Sapphire R9 290X | Ssd - Kingston Hyper X Beast 3K 240GB | Psu - Corsair HX850W | Case - Fractal Design Define R4
https://linustechtips.com/topic/57658-h220-pump-speed/#findComment-789926
I figured it out. I have it running at 1300 rpm. Controlled on motherboard
https://linustechtips.com/topic/57658-h220-pump-speed/#findComment-790308
1300 is about the lowest rpm it can go...mine sits at 1300 when idle.....even at full load at stock it stays at 1300ish +/- 50-75rpm
https://linustechtips.com/topic/57658-h220-pump-speed/#findComment-791159
