Laptop for my specific needs
Go to solution Solved by don_svetlio,
1 minute ago, oxitran said:
Strange I just noticed that their configuration builder think actually says a rear battery option yet the previous page said it didn't. I would have to ask them directly.
But it is exactly what I wanted, maybe not the price but that cant be helped.
In case its a no go do you know of any other options?
Hmmm. Their X-series is also good for battery. HP Elitebooks are also solid for battery (not as good tho) and I guess you COULD get a gaming laptop.
I already have a very powerful gaming pc. However, due to an upcoming move of country and my future leading to a lot of further moves in country in the next few years, I have decided it would be best to invest in a laptop.
The ideal solution would have been if the new Lumia phones ran an x86 build of windows but I digress.
The laptop would be meant as a 8 week desktop stand in while moving, and then as a portable pc and stream companion to the desktop while not moving. I would like to have it for as close to a decade as I can so I want it to be as new as it needs to be for future proofing where it matters. So unless in 2 years they find a battery solution that allows for 30 hours of intense gaming in the same form factor as the normal lith-ion batteries, I wont need an upgrade realistically.
The specs I want are realistically:
Any i7 with 4 cores, 8 threads, around 3-4 ghz.
16 DDR4
A 256gb SSD or m.2 drive (does not need a storage HDD)
A matte finish 1440p or 1600p non touch screen. Basically best ppi to battery hour performance, I also dont care for 4K on a laptop.
Small and portable but not so small that I would wallow as to what could have been with windows 10 phones. Basically not a hulking beast like most gaming laptops, but as close to the form factor of the dell xps 13 without being a detriment to performance.
Usb 3.1 typeC, the full connector not that pseudo crap they have in some laptops. lan port, the faster the better but not to picky. a sturdy power connector that wont break in a year and leave me with a door stop.
As quiet as possible without burning a hole in my legs.
And as most would want, not a flimsy screen that you feel like your bending each time you open the thing.
Does such a laptop exist or is it to good to ask for?
PS. I dont care much for graphics cards in a laptop. I know some dedicated graphics would give it more longevity but to be honest my i7 4770k can run most games that have come out in the past 3 years with no issue, so unless nvidia starts making their own laptops with custom motherboards with i7 intel chips and gtx 1080ti's or whatever their hbm ready card is, I reckon the laptop could make it the whole decade with just the intel graphics.
https://linustechtips.com/topic/576078-laptop-for-my-specific-needs/
Lenovo ThinkPad T460S - 10 hours of max usage battery life
Thats one hell of a close fit, but if you look at the models 2 have a dual battery config to get 10 hours, while 2 do not. sadly the only i7 model does not have the dual battery setup and some reports of only 4 hours.
Also damn that is a steep price increase for the i7.
And the ram has a super weird config, not a deal breaker but real strange.
Go for the i5 and double battery.
