2pin fan in 3 pin slot?
JustKain
Go to solution Solved by airdeano,
welcome to the Linus Tech Tips forums!
yes, the third pin is for fan speed (tach). it'll just run 12v all the time the system is up.
will a fan made for two pins work in a slot made for a 3 pin fan? "pulled an old fan out of a power supply for scrapping want to know if it still has any use"
Thank you for your time.
Just
