Minecraft Server problem
Go to solution Solved by Pesukarhu,
In the config file, set online-mode to false. Also relaunching might help.
Hi, so i'm currently trying to make a MC server which me and my friend can play on. I've downloaded that .jar, ran it properly, but when i want to connect to it from another computer on the LAN, it says "Failed to login: Invalid session". The command prompt that runs the server says the following when i try to connect:
mcwtf.jpg.c602e73ca5eb139285806de0f52bdf
25565 port is forwarded. I don't know what's the problem.
https://linustechtips.com/topic/575605-minecraft-server-problem/
