The power connectors.
Go to solution Solved by Xusu,
We solved it.
Hes pover suply broke
Just now, Xusu said:
But how are they connected?
We tryed to connect them to the places the motherboard says but its not booting.
Follow the motherboard manual?  They have a negative and a positive position, so if they don't work, rotate it and try again.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/574521-the-power-connectors/#findComment-7522823
try reading the manual
you can download it online if you lost it
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/574521-the-power-connectors/#findComment-7522828
So we tryed both ways and we have the manual.
When we press the power there is a flashing light and the nothing.
https://linustechtips.com/topic/574521-the-power-connectors/#findComment-7522882
