Hello! I'm building my first PC and want to water cool it.  I made myself two builds with a 50$ difference.  One is completely custom water cooled and the other is AIO water cooling (the AIO is 50$ more).  Here are both of my builds, which one should I choose? If you have any recommendations, go ahead.  I AM EXTREMELY GOOD WITH CRAFTING THINGS (Like the custom water cooling things)!
Build 1: http://pcpartpicker.com/p/KB3KCJ    (Plus a few other thing that PC Partpicker did not have)
Build 2: The photos
p.s. I already have an SSD so I don't need one.
https://linustechtips.com/topic/573624-water-cooling-help/
 http://pcpartpicker.com/p/9FNfYJ / http://pcpartpicker.com/p/9FNfYJ/by_merchant/
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor  ($556.99 @ SuperBiiz)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($94.99 @ Newegg)
Motherboard: MSI X99A SLI PLUS ATX LGA2011-3 Motherboard  ($222.98 @ Newegg)
Memory: Corsair Dominator Platinum 16GB (2 x 8GB) DDR4-3000 Memory  ($109.99 @ Newegg)
Storage: Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($74.87 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB HYBRID Video Card  ($689.99 @ Amazon)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.99 @ Amazon)
Monitor: AOC i2267Fw 60Hz 22.0" Monitor  ($99.99 @ Amazon)
Total: $2162.77
I got a cheaper MB to add a heftier PSU that will allow you to run a second 980 Ti down the road.
If the previous MB has some features you have to have, you can swap it back.
I changed the 4 x 4GB to 2 X 8GB RAM as it's $30 cheaper and keeps slots free.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/573624-water-cooling-help/#findComment-7513656
Total: $2162.77
I changed the 4 x 4GB to 2 X 8GB RAM as it's $30 cheaper.
Thanks for your help! Would you rather get the one you mentioned or the custom watercooled pc I showed in the picture. (I have a 3000 dollar budget so, that's not my number one concern)
https://linustechtips.com/topic/573624-water-cooling-help/#findComment-7513679
I think the performance increase of the 5930k over the 6700k is more important then the sweet liquid cooled system of the second build. But I understand the fashion and appeal of a fully water cooled system. It would be something nice to show off. Either system will perform extremely well.
https://linustechtips.com/topic/573624-water-cooling-help/#findComment-7513719
Thanks!
https://linustechtips.com/topic/573624-water-cooling-help/#findComment-7513748
