So my current motherboard has this weird problem where it bugs out after a few hours of use (this varies.) When this happens, all devices connected to the USB ports directly on the motherboard will stop working and audio devices will make very odd noises. However, if I connect the devices to the front panel USB ports, they work fine when this happens. What could this problem be?
System:
Intel Xeon 1230 v2
2x4GB RAM
NVidia GTX 760
Mobo: Z77MA-G45
https://linustechtips.com/topic/573220-motherboard-problems/
System:
Intel Xeon 1230 v2
2x4GB RAM
NVidia GTX 760
Mobo: Z77MA-G45
im guessing you have tried resetting/clearing CMOS?
https://linustechtips.com/topic/573220-motherboard-problems/#findComment-7509146
4 minutes ago, NoLimitCrafting said:
Yes
1. Have you completely turned off ur pc? (out of wall and everything)
2. Is the 24-pin connector full plugged in (both ends)
If you have done all this, it could be a fault with the mobo. I have browsed around a bit and found this: http://www.makeuseof.com/tag/dead-usb-port-heres-how-to-diagnose-and-fix-it/ not sure if that will help :/
https://linustechtips.com/topic/573220-motherboard-problems/#findComment-7509206
Ok, I'll do what I can, but thanks anyways!
https://linustechtips.com/topic/573220-motherboard-problems/#findComment-7509209
Update or reinstall drivers?
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
https://linustechtips.com/topic/573220-motherboard-problems/#findComment-7509293
