[IMAGE LINK]: uNB57sf.jpg
So this just happens 5 minutes ago, I boot up my computer and this really weird artifact on the screen goes on, first time I see it. I reboot the computer and the issue seems to have vanished. I'm extremely curious, is this a GPU failure or some kind of monitor/cable breakage? I want to know your opinions on this please, I will update if this continues to happen...
https://linustechtips.com/topic/573194-weird-screen-artifact-help/
2 hours ago, Ooxaz said:
Is the possibility of a loose display port cable ruled out? If it was a GPU issue then you would think it would be more persistent.
well i have never seen a lose cable cause that. it could just be a glitch like i said a 1 time thing. its not super bad so its not like your GPU is dying or anything, if a reset fixed it and it doesn't keep happening you should be fine.
My CPU is overclocked, could that cause it?
