CPU HELP
Go to solution Solved by I am an SSD,
2 hours ago, DA MAN said:
BROWSING THE NET SMALL APPS AND WATCHING VIDEOS ALL AT THE SAME TIME USING 3 MONITORS, NO GAMING OTHER THEN USING BLUE STACKS TO PLAY BUBBLE WITCH ON...
GET THE DUAL CORE....seriously most applications you say you will be running is capable of running on only a single core. ......and to run them fast, it is essential that the single core has a higher clock speed.....the no. of cores doesnt matter here
you see ..there is a problem with getting more no. of cores....the clock speed for each core is being dropped as you go for more no. of cores...and this is bad unless you do CPU intensive tasks like video editing
1 minute ago, 167776_1454180910 said:
Few examples:
CPU: Intel Pentium G4400 3.3GHz Dual-Core Processor  ($58.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($44.99 @ Micro Center)
Memory: Avexir Budget Series 8GB (1 x 8GB) DDR4-2133 Memory  ($26.99 @ Newegg)
Total: $130.97
Generated by PCPartPicker 2016-03-28 11:14 EDT-0400
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($65.99 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.98 @ Newegg)
Memory: Team Elite 8GB (1 x 8GB) DDR3-1600 Memory  ($26.99 @ Newegg)
Total: $135.96
Generated by PCPartPicker 2016-03-28 11:16 EDT-0400
GOOD LOOKING OUT THANKS...
WHATS THE DIFFERENCE IN A LGA1150 AND LGA1151
https://linustechtips.com/topic/572872-cpu-help/page/2/#findComment-7506584
LGA1151 is for Skylake and upcoming Kaby Lake (Pentium G4xxx, i3/i5/i7 6xxx, Pentium G5xxx, i3/i5/i7 7xxx) + DDR4 RAM
LGA1150 is for Haswell and Haswell Refresh and Broadwell (Pentium G3xxx, i3/i5/i7 4xxx/, i5/i7 5xxx) + DDR3 RAM.
For example, Pentium G4400 needs LGA1151 and it won't fit in LGA1150.
Pentium G3258 needs LGA1150 and won't fit on LGA1151.
https://linustechtips.com/topic/572872-cpu-help/page/2/#findComment-7506597
LGA1151 is for Skylake and upcoming Kaby Lake (Pentium G4xxx, i3/i5/i7 7xxx, Pentium G5xxx, i3/i5/i7 7xxx) + DDR4 RAM
GOT IT...
https://linustechtips.com/topic/572872-cpu-help/page/2/#findComment-7506600
